how do u get the heater panel off (mk1)
need to replace the bulbs, i had a quick gander yesterday, i thought it was just the 2 little screws on the bottom?
thanks
  Suzuki SV650
It is I think, but you need to kinda force the clock out then force the heated unit out as its held in very nicely. Helps if you can take out the bit running alongside the lower part of it IIRC.
  Trophy
Yeah,
Need to remove stereo and surround first, then the there might be a strip underneath panel depending on year and then just 2 screws at the bottom of it.
To avoid scratching it, push it inwards then guide it down at an angle.
Mat.
