how to find your WEP key?
  None
Its usually located on the hub. Thats how I got my landlords one ;) (with his permission of corse don't wanna be nicking peoples internet connections now lol)
Dafthead
  Q8 E-Tron
Aiii, RTFM
if you can't manage that, log into the router and it will tell you the WEP key
rctempire
If you want to Find the WEP key, your best bet would be to connect via the Ethernet port on the router. Then log into the Gateway address, which on most routers is 192.168.0.1, or go to Start>Run> cmd, press enter, then type ipconfig /all .Take a look at the Default Gateway, note that down, then open Internet Explorer and type 192.168.xxx.xxx (replace xxx for the default gateway IP address). Log into the router, most defaults are admin as user and password as password.
Look in the router for Wireless settings/Wireless Security. The WEP/WPA/WPA II key should be in that section.
Tom
  EV (s)
LOL! Loads of information to allow someone to answer your question!!
What router is it?
Who set it up?
You wont find your wep key, reset your router. (RTFM= Read the f**king manual, might be a good idea in this case)
Unless you are good at maths, then you can guess the code.
Dafthead
  Q8 E-Tron
Take it back to the shop and tell them you don't deserve a computer, let alone wireless haha
  172 cup
if it wont let you log in with admin and password.. try admin and admin as username and password :D
