Looking for 182
Hello,
I understand that hubcentric spacers are the best option to go for, as they're safer because the weight rests on the hub as normal, rather than on the bolts when using a non-hubcentric spacer.
Now, am I right in thinking that a hubcentric spacer comes with bolts which allow you to secure it to the existing hub. The spacer then has 4 more holes which you screw your wheel into using your existing wheel bolts?
Is that right?
Next on my list of things to do is to measure from the top of the wheel to the arch at the front and rear, and then minus around 5mm from that. That will give me the right size spacers to get, yeah?
Sorry, I know nothing about spacers but I realise that I need/want them
Is that right?
