MK1 Clio Versailles
I've got an Immobliser on my MK1 Clio, not sure if it's original or an aftermarket fit.
Either way, the last few weeks it's began to play up. I've put pictures below of the setup:
Basically some times when I come to drive, the key won't de-activate the immboliser. Sometimes it can be as simple as turning the ignition on, unlocking my wheel and trying again.
Other times and the more prolonged periods I've spent 10 minutes fiddling with it, and it can be embarrasing when stuck in a fuel garage not able to start up.
On the most though the light will turn off as a flick it in the slot, then sometimes you have to hold it down for ages or in a precise way.
Anyone else had problems like this and any idea what could be done to fix it?
Ta,
Ta,
