Knack to setting gear linkage?
  GSXR + KDX220
Is there a knack to setting up the gear linkage on a 1*2? Had to remove mine (undone the pinch bolt)
And now its hard to get them smooth. Which gears are selected when the selector is pushed into the positions under the car? If that makes sense.....
Where is "neutral" ?
mgoode180566
  172 Sunflower
took me an hour of fiddling. i fitted the rod. stuck it in fifth and adjusted it. then checked it against reverse. lots of fiddling and you can do it. get a mate to help.
  Stealth 438'd 182
Ah it appears for people searching the forums.. Wack it in 5th on the box side .. Then get a mate to hold the gearstick in 5th position and tighten worked 3rd time lol!
