Knocking at idle
mgoode180566
  172 Sunflower
My 2000 172 has developed a knocking noise ( sounds like tappets if i didnt know better ! ) when at idle and clutch is pushed to the floor. Doesnt sound like clutch bearing either and i cant hear it from under the bonnet , only from inside and i seems to be coming from the driver side. As i slowly lift the clutch it disappears , only happens when pedal is hard against floor. Any ideas ?
  Black 197
That sounds like the Thrust bearing, Done the same thing on my m8's Golf GTI, Had the bearing replaced now its all good... May help may not but thats what it sounds like
Rossy182
mgoode180566
  172 Sunflower
In my experience a clutch bearing tends to squeal and also this cant be heard from the gearbox side. Leads me to believe its not release bearing.
Will be a s**t if it is bearing :(
Most likely it is though, from your description.
