Knocking sound on my Cup
Evening,
Keep getting a knocking/rattling sound which I also feeling through the steering wheel when I drive fast around roundabouts. It never happens on open road bends such as A/B roads, only when steering tightly around something.
Full on acceleration and braking it fine - no noise.
Can anyone help please.
my cup does it as well it is only at lowish speeds and over little bumps like a knocking noise,
she is going in on monday to be looked at
Tom
Power steering is fine. Everything seems to be ok apart from the knocking as I said above.
Renault have looked at it and cant find a problem - typical.
Ive got this but dont know what it is - finally worked out that going fast around mini roundabouts makes the noise so Im going to tell the dealer next time its in......
It bugs me tho!
Just had a thought - I know its not the weather for pushing it but does the noise occur in the wet? If not could it be a bush of some sort, like the front anti-roll bar ones?
Mine too, low speed corners with roughish surface taken aggressively with about half a turn on the steering wheel. Ive been wondering what it is, could it be a "feature" of the cars?
My Cup does the same and my old Megane Coupe did it for all of the three years i owned it and nenver had any problems.
Must be a feature of Renaults
thanx for responses.
It sounds like a feature of the car if this happens to everyone. Its like the annoying thud when putting into first gear at standstill or reverse for that matter.
I get the same on full lock to the right and going over bumps. Its more of a squeaky knock, if that makes sense.
  Clio v6
I get a rattling from my cup too, but I found out it was bad nerves. It was only the saucer hitting the cup.
Sorry couldnt resist
Its the limited slip diff - not like a quaife one on the Focus RS ,but same principle - cuts in too put the most power/grip on the wheel on the inside of the corner or outside depending on curve direction of corner! The knocking is the system working..............
I had a knocking sound the other day. Low and behold it was only the flamin devil who had jumped down on my car!
Anyway, my missus being a religous bird said "Quick Sangy, show him your cross!"
So I leaned out the window and shouted "Oi, get the fcuk off my car!"
Ohhh, the old ones get me every time!
CupSize - Could you elaborate on this please........ta!
Arjun
