Hello everyone,
I am a 2005 Clio 182 owner living in the Arabian Gulf. I recently did a 80k service (timing belt + pulleys, clutch, water pump, engine mounts) During the service it was noted that the input shaft seal was leaking copious amounts of oil and was removed. I am trying to replace it, however the dealer will only sell the transmission cover w/ seals for 600+ euros.
I only require the seals, therefore I was wondering if it is even possible to source these seals seperately. It seems to be a fairly common problem and I feel that there must be Non-OEM parts that can be sourced to cure this annoying problem.
Many thanks from now
