dynamique 1.2
Hello,
I was wondering if you could help...
Just bought a new car (cat D with no service history and 03 clio 1.2 dynamique with 50000 on the clock) and I took it in to renault to get them to check it over. They did a diagnostics test and came up with a load of airbag faults, which I knew would come up but also a few others. These are as follows (I read this off the sheet):
DF236 +After Relay Supply CC.0
DF137 Motorised Throttle 1.DEF
DF135 Brake Pedal Sensor Circuit 1.DEF
DF116 Fuel Circuit Functional Fault 5.DEF
Now I have been getting about 27 mpg (out of a 1.2!) and I am most concerned about this. Will any of these faults be the cause of this? Bearing in mind I am only keeping the car for 6 months are any of these faults worth getting sorted?
I also had the emissions light on for the first week of ownership but that seems to have gone off now.
Any help would be most appreciated!
