I dont have the diagrams to look at but im 99% sure the main beam will not be powered straight through the stalk. Two main beam bulbs will be 2x65watt so 130w in total (or 10-11amps) which can only safely be switched through a relay.
fixed! ok so i got 2 dodgy second hand stalks both people said that they were fine too appalling (sp)
i changed over the one that i had faith was definitely working as a final attempt before i pulled the tester out and guess what it worked!
oh thanks Joshydee the one you supplied worked a dream thanks for the other bit too.
now can anyone tell me where the reverse selector switch is? i need one!
thanks all
any info on the reverse selector?
first thing that came to my head when i read this was the stalk. I've had around 13 mk1 Clios in with the same problem always the stalk
