odd tyre wear
ok now my sister has a mk3? clio (latest one) and was just used as a showroom model before she had it so had done about 15miles and is from a well trusted local dealer, only thing is she has the passenger side rear tyre wear about twice as fast as the drivers side rear, they say its just a comman fault with them, is this true? any helps apreciated!
cheers
Jon
Tyre pressure correct ?? Is the alignmet/tracking out ?? Check the tyre pressure yourself & take it to get the tracking checked out
yup pressures are all correct, does no one else with a new clio have any problems with this then? is there even that much adjustment on the rear?
C
Clio1.6Rxe
wheel alignment i would say. another thing to think about is were the tires changed at the same time?
as i said it came out of the showroom with new tyres on, will get her to go to one of my friendly inde's and gt the alignment checked, is that something that would be covered under wareenty or not?
