Et43 speedline 2118s fit over them, if thin balancing weights are used. The palmer spec 2118s ( I can't remember what et they're don't) they fowl the cailpers.
You can also get cup racer spec with ET 48.5
Nice 1 this sounds like a plan an extra 5mm spacing sounds good and the slightly wider track will be an additional benifit
Im not actually sure UK spec cup racers did have ET38 wheels you know. I have one and i swear the ET43 version sits further out than the ones that came with the car. Never measured it but my ET43's rub more.
Are you sure? Id be more inclined to say UK cars used ET48 as well. If you look at the depth of the spoke on the ET43 wheels they are much deeper (heavier) than the ones fitted on the UK cars and when compared to the wheels on the Euro cars look identical. I dont see why they would have changed the offset for the UK cars.
Yes Euro car run 5mm deeper offset to accomodate the 5mm extra track of the rear hubs and keep the same rear track.
All my Cup racer wheels at ET43 and Euro cars i have seen for sale the wheels are ET48
