offset question
imprezaworks
  Mk5 Golf GTI :)
Got some track wheels which came off a ph2, offset is et38. I know the offset on the ph1 is 43? so should there be any problems? Car is lowered
imprezaworks
  Mk5 Golf GTI :)
Cheers. Need some spigot rings to make them fit. Bore size std is 60.1, I'vemeasured the bore on the new ones and its around 70.1, thats if I've measured it properly.
  182
They will be fine i run ET 37 on my superleggeras lowered on sportlines and have no problems at all.
imprezaworks
  Mk5 Golf GTI :)
They dont line up properly with the studs as the bore size is different, hence me needing a spigot to bridge the gap so to speak.
