As reported in a other thread when dropping my subframe I manage to sheer 13mm bolts that hold the small triangle support brackets in place. I manage to drill out one of the bolts, but one of the others threads has been over bored. The bolt is located in the subframe where there is no way of getting a nut in there, so im guessing this is a common problem as the bolts was brittle as hell.
I was thinking of cutting a small inspection hole in side of the subframe, enough to slide a spanner end and nut in, then use that to tighten the bolt up, would this be fine?
Sods law that the one that came out easy was the inner one where its open and can see the bolt end grrrr
