power wiring help required, mk1 clio
  mk2 172
hi, we have a mk1 clio oasis and iv just put a saxo cd player in it, everytime the ignition is off it needs the pin re-etering, but if you turn it off while car is running then back on it works, howver in the saxo it worked regardless, i was just wondering if its an easy job to avoid this problem and bypass the ignition somehow for permanent stereo power?
help appreciated,
craggy
you shouldnt need to cut any wires
the pins in the ISO block do actually come out if youre forceful enough
pull the red and yellow cables out of the iso block and swap them round
should then work
  mk2 172
cheers fellas, will give it a go when i get home :), so i just need to swap a red and yellow around, mnit i hope it works!
