Question for Ukaskew or anybody that knows the answer!
M
mij29
If i set my shutter speed to anything over 1/160 and press the shutter half way down, the picture in the view finder is completely black and so is the photograph.
Why is this? Ive noticed some pics you have taken are up to 1/1000, all though my camera goes up to this and beyond it's dark in the view finder. :(
This is in the daylight not in a room at night time.
Washington
What aperture have you set it to? If you speed up the shutter then you'll have to let more light in by increasing the aperture.
  Carrera 4S. Clio 172. M5
Thats the depth of focus check, you should be able to over-ride that on the lens ring ?? dont know the camera...sorry.
Washington
Aperture controls the amount of light that passes through the lens and hits the sensor, it's not solely a control for depth of focus. You need to increase the amount of light that can get in to compensate for the shorter length of time the sensor is exposed.
M
mij29
A,P and m are all th same. I think it might be because it's a dull day because if pointed it up to the sky it wen't a bit lighter.
It's a Panasonic Lumix FZ30.
  Rally bus
If it's the shutter speed you are wanting to alter (while letting the camera sort the aperture) it should be in S mode if you have one.
Check your ISO/ASA as well, on grim days like today you'll need 400 at least - if it's on eg 100 then you'll struggle to get any light in the pic at 160th.
JMR
  RB 182 Cup
He got there before me.
Change yr ISO setting. If you're indoors, you'll need a setting of about 1/4 sec without flash with the shutter wide open.
As GaryS says, ISO 400 should do the trick. Anything higher you'll end up with noise/grainy pics.
