quickest 16v/williams cam belt method
Ive heard all sorts of theories and times quoted for replacing the cam belt and tensioners on a 16v/williams. quickest i heard is 2.5hrs by Nick Hill - there must be a special method to be able to do it that fast.
Whats the best approach in simple terms? e.g engine lift/drop or remove the following.....? etc etc?
any advice based on experience is much appreciated
  172 cup,s2 rs turbo
bet he doesnt replace the idler wheel if it only takes him 2 1/2 hrs.put the engine on a jack and remove the top engine mount.jack the engine up so you can get your hands in.
  williams and trophy
yep as above.............
took me about 4 hrs .....on the back street with no ramps, power tools etc..
just a jack n a socket set lol
I would personally move the whole engine aside by undoing the nearside hub and pushing the whole lot (less engine mounts) to the nearside of the engine bay. Gives you a few inches to work with.
With that method though, you only have to undo the loom and fuel rail to get the engine out.
