R.S Tuner... advice
  Yozza'd Titanium 182
Seriously considering one of these, im just a little unsure about plugging my car into a computer!?
Sounds silly but has anyone had any problems with these? Are they worth it? Does it affect your insurance?
DaveDreads
Affect your insurance? Depends if you tell them.;)
Yes it will, any increase in power like cams, remap, throttle bodies will put it up.
I've got one of the older ones and i've never had a problem, as long as you upload the correct
maps for you car then it's safe, however if you upload the wrong maps it will f*ck you ecu,
but you'd have to be a bit thick to do that. The're all VIN number specific.
DaveDreads
You won't f*ck the ecu, and yes it's worth it.
I got so use to mine that I forgot what it was like before, so last summer I put the
original map back on for an hour and I thought my car was broken.
I'd forgotten that an RS clio has nothing before 5k rpm lol.
  BMW E82 M Sport
You'll be lucky to get hold of one mate, but i hope you do :)
If you want it done by a pro i've got a group buy running at the moment for a custom remap at RS Tuning
imprezaworks
  Mk5 Golf GTI :)
The questions the op has asked had been my concerns aswell hence why my name is down on the group by at rs tunning. It's in safe hands then, he's got a great reputation.
Dan.
marcushookdale
  rstuned 182ff bg
whats the price on this custom remap, or are they different ££££ for different maps ??
sorry to sound a bit backward but just tryin to educate myself abit on rstuners/remaps but 1 thing is for sure i 110% want/need 1 for my 182
i just wish the new rstuners were easy to get hold of,
marcus,
Only way you'd f**k the ECU up is if you uploaded the wrong software or a map not designed for your ECU or if your laptop crashed whilst uploading a map.
Really easy to do and makes a noticeable difference.
  Golf GTD Mk7
Do it. Really easy to do.
Yes it's worth it.
You should tell your insurance as it's an engine mod.
You and your insurance ;) To be honest they'll never plug the car in to check the mapping on it, and even if they did I doubt they'd be able to tell.
It is a good bit of kit and the car drives much better for sure. ECU is backed up on laptop before the you upload the new .cal file. The only thing I found hard was locating the correct files for my car. If you do a search on here there is enough info to get you through it.
REMEMBER TO HAVE LAPTOP PLUGGED IN OR WITH A GOOD BATTERY!!! FOR ANY ECU WORK THIS IS A MUST TBH.
