Rear disk 'wobble'
Guys,
Just put new disks on but they wobble like the bearing has gone excessively.
Could this be because the washer is missing i cant remember seeing one when i took it off and have checked the old disks?
Also are all rear hubs on the 1*2s the same?
Regards
mossyv6
  Trophy,V6,5GT,AG200
Have you tightened the hub nut up sufficiently? the discs still move until the hub nut is tightened down.
mossyv6
  Trophy,V6,5GT,AG200
Even without a torque wrench it shouldn't move - I would also suspect the back spacer is missing.
  Clio 172 phase 1
You've lost the spacer ... Don't keep driving it you'll end up ripping the stub axle off and causing a horrid accident... Get onto renault or make a new spacer :)
Darren S
Those little washers are a right PITA! Have you made sure they are the right way round too? The bearing will fail prematurely if they are wrong.
D.
