Rear speakers
  Ph 1 172
right ive got a 1.2 199 mk2 phase 1 clio. it has not got rear speakers at the moment im not intrested in 6x9 (well i ould like to avoid them if i could anyways car becomes more of a target with them sticking out) so what im asking is i have seen clios that are the necxt range up with speakers in the rear panels like buy where the cup holders are for rear seats. is the wiring already there and mountings to fit rear speakers or is it a hard job than im thinking??
  172 mk2 Iceberg
dont dother
you will get a better sound stage with uprated and amped fronts
combined with a small sub ?
  Ph 1 172
yeah see ive already got 2 12s and a 10inch sub in my car with uprated front speakersand tweeters just want the rear speakers is i wanna fit screens for the real surround sound if you no what i mean
  RB 182
Just put mine in there a piece of piss. If you take the panel off that is part of the drinks holder as well then there should be a hole already there with screw holes as well (cheap bastads leaving the speakers out:mad: ). There's no wiring so you need to run sum speaker wire through the hole and under the plastic edge upto the passenger footwell and then up into to HU. You will probably need to cut the wire at the back of the headunit to be able to add in the speaker wire but it's pretty simple took me about half hour to do it all:) . Hope this helps, Rob
  Ph 1 172
cheers mate after reading that seems easier to wire up my spare amp and just run set of 6x9 and 5 1/2 speakers of it thanks guys
