removeing door cards
  Chocolate Bar™
use a torx bit to remove the door handle bit (with the electric switches in) and the actual door handle. the electrics to the switches are just a terminal block you can disconnect.
then you can remove the small section around the wing mirror and up the B pillar, this just pulls off. then you have about 3-4 screws in the bottom of the door card you need to remove. once these are out i think its just connected via plastic plugs, so its a matter of pulling the door up and then out as its lipped over the edge where the window is.
its rough, but if you look at it logically its easy enough to sort.
