Was wondering if there was a guide knocking about for this? Wiring and doorcards are already out, but was wondering how to get the window out in the safest way? I assume the motor is as straight forward as unbolting and removing.
I'd imagine you'd have to pull the window rubbers right out, and then drop the window to a certain point, and you'll see that the mounting brackets on the window-regulator will line up with holes in the door. Undo the bolts/torx and then lift window out of the door frame. I haven't took a clio window out before but most door windows on cars are similar in removal.
There's a clip at the bottom of the widow connecting to the winder mech, disconnect this and lower window down. As it slides down ease the window out of the shortest widow guide rail and it'll just fall free. Think the shorter guide rail is at the front, where the shortest part of the window is. Then remove winder mech etc..
