Removing scratches which are reasonably deep
Waitey
  Alpina D3, AC Cobra
Gents,
I have a few scratches I want to have a go at.
They are deep enough to feel with your finger nail, which would be the best way of improving them?
I have a Menz cutting pad, 3m cutting pad, 3m fast cut plus, Menz IP, Menz final finish and a Menz finishing pad, along with SRP.
What would you use? And what method would you use?
  Golf GT & A4 Avant
if you can feel it, you'll be removing lots of clear coat if not all trying to remove it entirely. best to just go over it and smooth of the edges so it is less noticeable but removing it I would imagine is unlikely
  2007 clio dynamique
I would touch them up leave for a while and then machine polish to try and blend them in maybe not the best way to do it but should work ok
Factory paint job? or has it been custom sprayed? you'll need to wet sand it to do it half quickly, so id be wanting a paint depth guage myself or having knowledge of the paint job.
Waitey
  Alpina D3, AC Cobra
Factory paint onto fibre glass. Lessening thier appearance will be fine. I'm aware i won't be able to remove them.
