Renualt specialist central Scotland
RichieJA
SCAMMER !!!!
  clio 172
Can anyone recommend one, I'm becoming convinced that the timing belt receipt I got with my car is fake as the aux belt has 100% not be done unless the belt looks well worn after 1500 miles he says it got new alternator and battery at the same time and which i can see are very new and I would like it check car is due one in 4k miles if its not been done, seen all the horror stories so if it needs done I want it done right but don't fancy paying dealer prices
RichieJA
SCAMMER !!!!
  clio 172
Thanks i had engine mount off today and timing belt looks brand new still shiney and dirt/oil free but the aux belt is all cracked and I'm slowly using water some reckon water pump is leaking so need that and aux belt done so need to visit one anyway
  225 Cup & Williams
Personally I'd get the Cambelt kit changed too for piece of mind.
Just because the belt looks fine doesn't mean the runners/pulleys will be fine.
MarcB
  182 Trophy & 197 F1
Timing Belt Kit
Aux Belt Kit
Dephaser
End Caps
Oil Filter
Oil
Water Pump
Coolant
SWR do the above including parts labour & VAT for around £620ish
RichieJA
SCAMMER !!!!
  clio 172
I have a recipet for the belt been done in August I was just slightly suspicious prob just being paranoid that why I had a look at the belt the recipet has new battery and alternator on it, can clearly see are new but why change timing belt n
And alternator and not aux belt can't think of reason for this??
RichieJA
SCAMMER !!!!
  clio 172
Checked recipet says timing kit new battery water pump £540 done by elite autos in Warwick
Can't be water pump that's I'm losing water out of then.
I won't feel 100% safe till that aux belt is done what does that usually cost?
