Reverse fuse symbol
Hi! Trying to get my reverse lights to work again. Definately not bulbs. Convinced its a fuse. On the fuse map, what is the symbol for reverse lights??!
Use a tester and check youre getting power through. Just check all the fuses if you cant tell which one it is.
Thank you muchly! Have checked all and found one broke with the symbol for amp. Changed this, but reverse lights still dont work. All other fuses are fine. Cheers for the advice chappy!
