Ok mot emissions but isn't it still good to go through the mot with the rs tuner map on?
And on the idea of it being expensive to individually map each car, I thought the rs tuner map was a generic 1#2 map?
Still want one though!
MOT emissions! High and low of it !
It will still pass with the RS tuner map , but you may have to warm it up before hand , although most standard clios require this too, also another reason is Renault didn't map it like this is fuel , a lot of people don't want to have to buy super unleaded , and obviously Renault had to cater for 95ron as well!
I really prefer mine now it's done feels a lot better to drive !
Main difference is that it corrects the fuelling from 3.5K or so upto 5K where its too lean at full throttle as standard as it holds the car on the lambda sensor.
Thats what causes the lack of power under 5K, otherwise known as the "5k kick" that for some reason some people on here think is a good thing for a car to have a big hole in power just below 5k.
Renault specify super only for the 172/182, its got a sticker in the fuel flap to remind you and everything.
They are allowing a lot more headroom though, old fuel etc.
I was referring to the difference between rs tuner map and standard map.I notice no difference in the hole which ever petrol i use tbh, or any difference in perfromance.
