seat bolts
If your taking standard seats out. All the bolts from them are welded to the subframe which is attached to the seat.
You'll need new bolts to bolt a new subframe to the car. I just went to my local hardware store. Can't remember the size exactly but its a very big hole. I just guessed a size closest the the standard bolts I could find. Cost me like £2 for a set of 8 chunky bolts including washers and nuts.
Even if the bolts are not big enough to perfectly fit the holes in the frame or the chassis you can just use a chunky washer.
