ilovewilly
I'm planning on extending my single, pitched roofed garage to a triple, and I'll be using this thread to document and ask for advice along the way from those in the trade etc.
Now, I'm only in the initial stages of designing and estimating material costs. I may well end up scrapping the self build element if I can have the shell done by a builder for a reasonable amount - but cost may well dictate that I have to 'have a go' without any previous building experience. YouTube FTW.
The existing garage single skin and attached to the side of my house. I will be retaining the existing building and adding
5.2m x 5.2m Total area – 27.04sqm.
A triple garage attached to the side of a house on a suburban housing estate may look a bit intrusive, so I'm considering how I am going to place doors to the front. The image below shows scale with 3 standard single garage doors. *note the internal wall is the existing external wall, and would be removed. I've left it in for scale so I can picture the area split in to the single size.
I drafted that up on floorplanner.com. I really need to grasp something better like SketchUp.
My other option is to perhaps leave that internal wall in place, to add separation to make it possible for a future home-owner to have perhaps a utility with a double garage attached - which would save me demolishing, removing the material and would enable the existing space to hold my belongings whilst work is under way, unless I removed it at the end when watertight.
3 doors, all singles does look a bit like a block of garages. So I considered having a solid wall to one side and two single doors.
My house is brick with a rendered porch, so I'd be tempted to render the outside to tie it in, and arguably it may well be cheaper than facing bricks plus it covers up DIY block laying with half arsed messy pointing. Thinking back to my earlie thought of making the build future friendly, I have considered blocking up my exiting garage door and leaving the internal wall with a double to the side so it looks as if its a utility with a window to the front - with in reality a car shuffled over to the side on go jaks or using that left side for storage/workbench.
I won't bore people just now with my initial material quantity and cost estimations. My initial assumptions are that I can build this using single skin, 100mm block work. I don't feel the need/expense of making it double skin, insulated. Due to the upstairs layout of my house I can't see me ever building up. I've no current damp issues to report with the existing single skin garage.
Any considerations or queries appreciated to get me thinking and help improve the end product.
