Snapped map sensor
  Ph1 T
Trying to get it out I snapped it on the bit where it pushes into the inlet. Now the only other one I have is a 2 bar one could I fit that? Or will I need a standard one?
Dan
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I believe the 2Bar should work just fine chap. How did you manage to break it though, Ham fists again?
  Clio T 314hp c43 AMG
Did you get the bit you snapped off? If the one you snapped is a 2bar then it will be fine if its different it won't as its been mapped.
  Ph1 T
Mick I was just wiggling it about to try and get it out for painting inlet and just snapped on the kneck...
No it was standard the one that broke so can't I put my 2 bar in?
  "Navy" N17 TWO
This happened to me once too, the little bit flew inside the plenum - I nearly shat myself!
Got a spare pretty quickly on here though :)
  Ph1 T
Got one sorted but Won't be sent till tommorow so have it Tuesday hopefully. I've managed to silicons where the sensor snapped back together and it's gone in as a temp solution till new one comes
