Spark plug change 172
LiamR172
Scotland - NW
You need a socket for the plugs and an extension and the socket to remove the bolts on the inlet... i think.
  Lionel Richie
that guide is wrong in places, don't unbolt the coilpack, just pull the leads off (they're numbered anyway, so you can't **** it up)
and you shouldn't pull the MAP sensor out the plenum (easy to snap) just unplug it (number 1)
same goes for number 2, just unplug
Okay do I need a special plug spanner? I have a normal one you can get in halfords... As I say my old clio required a special long one. Also how long does it take roughly to do?
Many thanks
  172 Cup
I also covered up the lower part of the inlet manifold to prevent any crap getting into the inlets. Perhaps a bit overly cautious, but i'd rather be safe than sorry!
