speakers
  clio sport 172
hey people can any one tell my how to remove and change the rear speakers on the 172 , and the front's and how to change the tweeters is it easy to do ..
  clio sport 172
does anyone now if it is possible 2 fit vibe speakers in the frount door panels own 2 the fact they have got the big magnects that stick out can anyone help
  BMW M135i
They'll fit but you'll need to chop the door card. Rears are easy the covers just pull off then 4 screws. The fronts are more interesting if you want to fit components, dashtop has to come off at least.
lemonnobby
you can get to the tweeters i think by turning the little panels and the pop out. not sure if the access is any good though
  BMW M135i
Won't get to them very easily by taking the covers off, certainly won't get the originals out and the new ones connected.
  clio sport 172
cool thnaks people
yer to do tweets got to take dash out , fornt speakers does the plastic just pop off but would i have to take door card out to fit cross over i think and how dose the back panel pop off ,
and the speaker are the ones with the stick out magnet , will they fit in there mounting size is 115mm and a depth of 60mm and ideas guys
  BMW M135i
Front panel has two clips in panel which you'll see if you get down and look at it, the rears you need to take the rear seat bottoms out and you can just pull the rear covers off.
As I said above the vibes will fit but the rain guard will need to be cut out of the doorcard, I decided against this and fitted some infinities which fit without any chopping.
The trouble you have is it the tweets are in the dash and theres no easy way of getting cable into the doors, i've got around with by making some adapters and putting the crossovers in the dash.
http://www.cliosport.net/forum/showpost.php?p=2113021&postcount=3
Read that, its how i've done it without any major modification to the original loom. If it doesn't make any sense then ask away.
