Shhh
182..
Put it in reverse and full lock on, the front brakes squeel. As you ease the steering to the centre position it drops off. Once you go forward it goes back to normal, no noise, nothing. Brakes work fine.
Just steering in reverse, had the pads changed not so long ago. Brake disk wear was close to manufactures limits, tho nothing dangerous. Brake man in garage removed the edge of the disk, and advised me on KwikFit & Renaults policy on changing disks with pads when not needed etc.
Only other thing is i have that bouncing wheel thing when in reverse, suspect it to be a suspension mount or something but on the other side. No idea what can cause it to squeel only in reverse with lock on.
