Still Knocking ! help
  Clio 172 Phase 2
Hey guys so my engine been knocking(vibrating) in 1st and 2nd under hard acceleration. changed top engine mount ( and placed it far foward) and changed dog bone mount.
And go for a spin and its still making a noise only in 1st and 2nd. any1 local to fareham wana come take my car for a rag to diagonse this problem as im losing hair over this !
Cheers Carl
  Clio 172 Phase 2
is it when u lift your foot of the clutch when quick shifting into and from second?
Nah its wheni boot it in 1st and 2nd, for example il be in 2nd gear open her up at 2000rpm sounds all good till it 4500rpm then sumink vibrates all the rest way up rev range.smash it into 3rd then has tiny barely noticable vibrate up the revs
  FF 182
have u poly bushed the dog bone?
  53 Clio's & counting
IT could be yes, but take a snap of the top moutn, i want to see how farward you have put it, as I fell into the trap years ago with this and i didn't think you could move it very much but you can move it quite a lot.
The dogbone mount is the one under the car - you can get harder bushes called poly bushes which stop alot of the movment.
  Clio 172 Phase 2
IT could be yes, but take a snap of the top moutn, i want to see how farward you have put it, as I fell into the trap years ago with this and i didn't think you could move it very much but you can move it quite a lot. The dogbone mount is the one under the car - you can get harder bushes called poly bushes which stop alot of the movment.
Alright yea took dog bone off. And the bushes looked fine and solid. And the top engine mount I completely removed cambelt cover. So mount was free and moved it about a inch forward lol.
Cant be asked to take it garage cause will get costly. I need some 1 local to take it for a drive and see what they think really. Only
other thing i can think of is top gearbox mount. If its anything to do with exhaust I wouldn't no where to start
