Stop and battery light flickering
  KTM 990 SD / S60 D5
As above only really happens when everything is on ie heater,lights,stereo,car has had a new battery recently,I have the cup alternator set up on my 182 and I am thinking it must be down to the alternator which I think is a pattern part.
Do all cup alternators have ring terminals or the same plug as the 182 alternator.
  182, SQ7, Trafic
You'll have your main power cable and a two pin plug with one wire.
Check the little plug isn't loose
  KTM 990 SD / S60 D5
So the connections on the cup alternator should be the same as the 182 one?the alternator I have does not have the plug it is a ring connector.
