STOP light & BRAKE light flashing
  Black 172
Whenever I pull away on a steep hill the STOP light and BRAKE light flash rapidly. It also does it when I'm accelerating hard.
Any ideas why? Thanks.
  VaVa
Check your brake fluid level. Also check the condition of your discs/pads.
It flashes due to the fluid sloshing around in the resovoir and going below the level sensor.
deffo...100percent your pads..
it will flicker on sometimes when going up a gentle slope or going round corners fast.
  M4 LCI, X1, ZX10R
It's because your brake fluid is too low.
Probably check your pads, if you replace them the pistons will go back in the cailpers and raise the lever of your fluid.
Check the pads before topping the fluid up.
