Tarted Up Footwell
Why have you not got the correct colour flooor mats, they look alot lighter than usual or is it the camera angle.
  Clio 1.6 16V
These mats are not standard 172. My original drivers mat wore through under the throttle pedal after 300 miles! ...... quality ....not. My dealer then gave me a new set of Clio executive mats under warranty hence the different shade. However, these mats are very good quality.
  Clio 1.6 16V
E_Lad, that idea crossed my mind but thought it was a bit OTT. Seen a valver on this forum with full metal and it did look pretty good.
  Clio 1.6 16V
My mate at work actually bought a 50cm x 50cm sheet of "Cricket Weave" alloy plate from B&Q for about £20 to put a heel pad on his TVR. So I went halfers with him and tried it as an experiment to see how it looked. Its about 2mm thick and cuts very easy with a metal gillotine or hand cutters. I used a joddling tool to crimp the edges. As you say E_Lad it may be a bit slippery in the wet .... that remains to be seen.
Close up of material with joddled edging....
http://www.fifegallery.co.uk/domains/cliosport/mat02.jpghttp://www.fifegallery.co.uk/domains/cliosport/mat02.jpg
