The DIY Thread
Crazylegs
  Clio 182
We've bought a book recommended by a trader called DIY - Know how with show how. It's a brilliant book with clear guidance for doing pretty much anything in or around the house, worth investing in.
  2005 Fabia Vrs
Thanks. Just ordered one off eBay, I need all the help I can get. 🤣
Ol’ Tarby!
  Clio 220 Trophy
Got it from a motorway services a few years ago for a 5er. Bargain
Cookson
  Mk1 Audi TT 3.2 V6
Done a little graft over the bank holiday. This wasted area at the front was just full of big ivy roots and weeds. Probably used to look nice in the 80s.
So I decided to dig it out. I want it fairly flat so I can lay some black sheeting down and put some low maintenance white stones one. Thinking maybe doing a 90degree decking planter in the corner.
I have done 3 tip runs and reckon I've moved about a tonne of soil and rubble, along with the roots. I'm fucked now, so going to have a cold beer or 6
Breamy
My dad has made a suggestion.... and he’s going to cost me money lol, he’s suggested I extend my garden bricked wall out.. use that dead space out the front and make the garden wider - might be something to look into, I’d have to speak to planning I guess? But the space is just dead space - the previous owners weren’t gardeners by any means and just had 4 tons of gravel delivered, I want to returf it, it’d be so much nicer with some green! But I’ve had a quote for railings.. so worst case will turf and rail
You may struggle to get planning. We wanted to move a fence out and couldn't.
Also that would cost a fortune to rebuild the wall with footings etc
Luke
  Megane 250
Fuckin ell, what you planning on putting on it?! 😂
An extension by the look of things 😂
The decking I ripped up was rotten to f**k, and bouncy. Basically, I did the opposite to what the previous people did.
Really like working with wood tbh, the pergola I’m planning is going to sit over the new patio at the back. Can’t wait to get cracking on with that now!
Chuckles
Shame the pergola isn’t going over that deck, it would make a great base
  370Z, Fiesta ST2
The amount of shite decking you see where it bounces all over the place when you walk on it. Great to see someone actually making something sturdy! My dad went overkill when designing theirs, it didn't move at all even 5 years later - parts of it were around 1m off the ground too.
  E92 M3 Monte Carlo
Been doing drive at our new house. Apparently the drive that was down was original from 1970. Dug it off stoned it an block edged it, got tarmacers coming next week to finish it off
Coby.
I'm probably being really thick here but how the hell do you drill a hole so close to a corner? No way will my drill allow me to get so tight to the wall.
You should be able to just line up the holes with the rightmost side of the slots, any screw/drill/driver should be able to reach then as you’d be away from the part of the bracket that’s sticking out.
Luke
  Megane 250
Are you available for side jobs? :LOL: I want to put decking at the bottom of ours, but I've not got a clue where to start
Tbh mate it’s fairly simple! I went completely overkill with amount of posts I postcreted in, wanted it as sturdy as possibly as 1) it’s raised and 2) the back end is fastened to the house.
@Chuckles also laughed at me using 6x2’s.
Are you planning to use normal decking or composite? Just bear in mind with composite the spacing between rafters will be smaller than using timber.
If you’ve never done it before like me, just take your time with planning, get/borrow a chop saw and buy decent clamps!
Managed to get down a fair amount of mine the Saturday. Ran out of 6mm spacers which stopped the fun though.
I also realised the either a) I’m terrible at measuring or b) the house is at a slight angle, as the posts at the end don’t line up 😂 - spending tonight packing them out before the step goes it.
  MR2 Mk3 / Giulietta
You should be able to just line up the holes with the rightmost side of the slots, any screw/drill/driver should be able to reach then as you’d be away from the part of the bracket that’s sticking out. View attachment 1532900
Mark the holes with a pencil, drill at an angle as required, bang a plug in, tap it flush, drive a panhead screw in with a screwdriver.
SharkyUK
With the recent spell of decent weather, I was FINALLY able to complete the refurbishment of my oak front door. I had done the inside some time ago but Welsh weather, my busy schedule, and my lazy-ass meant the outside had been put-off until recently.
The inside looked like this upon completion...
...but the outside looked like crap.
The previous owner had used some dark stain on the exterior (which was daft as it just did not fit in with the oak used everywhere else). Over the years the door had been neglected and the protection was poor at best - which was a bit of an issue given the aspect of the house and the fact that it experiences the full force of most poor weather fronts and storms.
My poor software developer fingers...! 🤣 12.5 hours of sanding was required in the end but I was chuffed with how nicely the wood and grain 'jumped' out. A little bit of sympathetic filling was needed here and there, and a couple of chamfered edges had to be sacrificed due to minor splits, but overall the door remained solid, secure and stable.
A few coats of exterior varnish later...
I'm happy with how it turned out and it really has refreshed the house front no end. We have an oak porch that is being built August / September and, along with the changes we are planning for the front garden, I think it will pretty tidy. I hope. :LOL:
Luke
  Megane 250
Thanks mate! Sorted it a little while back.
After 20 minutes of scratching my head like a r****d 😂
Edit: r****d is in the swear filter!?
  DCi
Before I admit defeat let's see if I've missed something dumb...
Got a leaky loo - very slow drip where the isolation valve meets the refill valve (Feeds from the bottom)
Change the red washer in the valve, still doing it, changed the refill valve, still doing it
It's coming out the top of the isolation valve, so isolating means it's not an urgent problem so that's cool
There was no ptfe tape on the joint so I didn't put any on when changing stuff - assuming thats right? (That probably sounds dumb but I don't trust the house builders to have done it properly in the first place haha)
I don't really fancy changing the isolation valve myself because if I f**k it up I have to leave the water off so just checking that's all that's left before I call someone who knows what they are doing in because I've done the easy bits
My garden last year
And now
Ripped out the back fence ready for a new one. Taken out about 8 old concrete posts, 5 trees and absolutely ruined every square mm of my body over the past couple of weekends. Me and the neighbour managed to get the first post up on Saturday and overfilled 2 skips of s**t (The 2nd one is being collected today which will be funny to watch his face). There was so much ivy growing over everything it took us at least a day just to cut the old fence free, in the end I just broke out the chainsaw and went through the f**king lot
Pay for the smallest skip possible, pile it as high as possible 😂 There's at least 2 tonne of topsoil in that, I was very tempted to break out the wacker plate and start really packing it in 😂
My neighbours garden goes around the back of mine, the previous owners of my house were too tight to buy the land when it was offered so the neighbours snapped it up. I've gained about 3ft of garden removing all the trees and s**t and my neighbours have probably gained the same. The old fence twined with Ivy was about 2ft thick!!
Pictures just don't do the f**king job justice of how bad it was. My neighbours have more pics so I'll have to grab some from them
iimushroomzii
Toilet roll king
  Transit Connect.
Is it a flexi inbetween isolation valve and toilet? A pic would help?
iimushroomzii
Toilet roll king
  Transit Connect.
My garden last year
And now
Surprised you didn't just burn all the timber!
