Darren S
Chaps - I'm wondering if someone can explain the whole volts, amps, draw on the battery, etc to me.
I'm stumped when it comes to electrics other than changing a bulb or a fuse. I've got an issue on the Evo where if its not used for a few days, the car will simply not spin over. A new battery hasn't fixed the issue - and when tested, it doesn't appear to be loosing much in the way of voltage - approx 0.2v per day when not used.
When running - the terminals are reporting a healthy 14.6v, so I'm assuming that the alternator part of the equation is fine and doing its job? When the car fails to spin over, the voltage is usually over 12v on either battery (new and old) - but has dipped below that before now.
Therefore, am I correct in saying that it's actual amperage that isn't on tap when I go to start the engine? My limited understanding is that a starter motor needs a hefty clout of amps to spin the engine into life - and not so much in the way of voltage? If so, can amps get drained away much in the same way that voltage can?
I'm seriously thinking of getting an auto-electrician in at the minute (any recommendations, anyone?!) as I simply cannot rely on the Evo to start at the minute. It did a 60mile trip on Wednesday (mainly motorway miles) and when I tried to start it this morning - it didn't have enough amps to spin the starter motor - though the fan and radio came on. That's pretty piss-poor in anyone's book to go from running fine to virtually dead in less than 72 hours.
Any suggestions, thoughts, ideas, etc would be welcome. Aside from the annoyance factor, even I know that simply recharging the batteries is ultimately going to screw them up.
Cheers guys,
D.
Cheers guys,
D.
