Im wanting to improve the corner weight of the rallycar but need some height adjustment on the rear (one side only). What level of adjustment do you have will the torson bars ? is it min 20mm increaments of can you get say 5mm increments.
The scales are telling me i need to adjust the right rear weight so need to raise just this corner to correct etc.
Any info welcome....
The rallycar tipped the scales at 914kg (1/3tank fuel)........quite heavey i thought but it done run ali sump guards/tank guard/fully cage/extinguisher system/heavey wide slicks/Willy wheels and handheld ext/fuel swirlpot system etc etc.....but definately potential to dip under 900kgs.
