Torx head tool kit
any found a good Torx head kit? i could reallu do with a good set of standard Torw head sizes that compaitible with 1/2" drive ratchet and also will either have a seperate set or will work with hex fit interchangable screwdriver etc.. Anyone reccomend a good one??
Needs to be cheap of course! But not crap like a 1 pouns set i got bought by someone from the m,arket where the heads shear off at the sight of a bolt!
any normal motorfactors will do them.
The likes from most tool manufacturers are fine, halfords are a bit pricey.
bout 30 off quid should get yout a set of torx bits and sockets.
I just got an adaptor that takes hex head screwdriver bits and then the shop i work in sells the individual bits, got about 25 different sizes, think ive got all the sizes used on clios, i also have some allen key - shaped ones
