Turbo Clio by KTEC preferably
Chi
  Z4, VW172, R26
After much indecision I have concluded that a modified clio turbo would be preference for my next step into the clio scene.
If anyone has a nice example please let me know as I would be interested. I have mentioned KTEC as I know this company to be well respected however I would consider other reputable specialists. Thanks in Advance :evil:
  182, SQ7, Trafic
Engine dynamics and do your own one, it'll be better than the prices dreamers want for an already completed one
LiamR172
Scotland - NW
Ahright!
I remember seeing it last year. Think it was about the same price actually. Used to be in Scotland.
Dont think i could pay that much for it!
  Countryman JCW
Ahright!
Yeah i think i remember it too... it was up for £5k then and said to be running 305bhp.
Nearly 6k is strong money for an 02 plate clio regardless of its spec!
No doubt it will be mental though!
LiamR172
Scotland - NW
It would be insane, and having full interior etc would be comfy enough as a daily. If the engine can put up with that!
But it would be my luck to pay 6k for it and it would blow up on my way home!
Chi
  Z4, VW172, R26
Ha yes its lots of money for 02..
That link to the car Daniel posted seems cheap to me given the amount of money gone into it. Though because K-Tec have 'built' it, i'd never buy it, would probably need the same amount of money again to be fixed/done correctly.
I like that a lot, but it is a lot of money for a second hand tuned car. Even though it would cost a hell of a lot more than that to do it yourself.
As Nick says, wouldn't fancy owning a KTEC car now anyway to be honest, would be too concerned about the mapping.
Chi
  Z4, VW172, R26
Why is that?
Chi
  Z4, VW172, R26
KTEC not as reputable as I thought then?
  182/RS2/ Turbo/Mk1
Top speed: 150
Surely a car with near 400 horse will do more than 150mph? Considering a standard one does 140?
Depends on how it is geared and what the rev limiter is, mine pulls over 170mph quite happily with not much over 300bhp but if I put a lower rev limit on it (mine is 7800rpm) and I used a ph2 diff not a ph1 one, then the same power would only get to 150mph before it hit the limiter.
A ph2 clio with a normal rev limiter and standard diff wont go over 150mph even if you have 800bhp
  182/RS2/ Turbo/Mk1
Is this the same one? Cause its not as quick as i was expecting
Here is what my 300bhp full trimmed road car with full glass, rear seats and a radio etc does to a 200 on track:
And yes he was trying, there is another thread on here where has posted footage from his car.
Full session video:
300bhp in a clio is VERY effective as a trackday car, I really think people need to go in a properly setup one (of which there are very very few) before they start chasing more power than that. Getting PROPER control of the power and getting a decent controllable spread of torque is so much more important than the peak figure.
More power in mine would make me no quicker in the bends, no quicker out of the bends, no quicker at the start of the straights, no quicker at the end of the straights under braking (ie all the exciting bits of the track) so only place it would make me slightly quicker is the middle of the straights where TBH Im already doing 150mph so is there really much point? All it does is make the brakes work even harder which means I wouldnt be able to run 15ss anymore and would start making me slower on the corners I suspect.
Chi
  Z4, VW172, R26
I'd personally sooner see you download a TomTom map of beligum onto your car than one of their maps from what I have seen, but maybe I have just been unlucky and only see the bad ones.
Lol what if you were to buy and take it to be remapped? Still cheaper than starting from scratch.. That video is awesome!
Cub.
Depends. If the mapping is out, and its done some miles with that map on then the damage may already have been done. So remapping it won't solve the long term potential issues. But, I have not seen or have any experience with this particular car. It may be a great car. It may be a lemon. Who knows.
Chi
  Z4, VW172, R26
Chip ill take it ;) what did urs cost to put together and who did you entrust to do the work?
Chi
  Z4, VW172, R26
RAC inspection haha
  182/RS2/ Turbo/Mk1
that's a very bizare dyno graph, peak power at just over 5000rpm then it just falls away!
Turbo maxed out and then the engine's VE just drops off where its trying to keep it spinning and that results in high exhaust back pressures at a guess, probably an effect exaggerated by poor mapping.
  182/RS2/ Turbo/Mk1
Mine was the MWM demo car originally, so I re-used the external parts to the engine for turbo and manifold etc and ECU, effectively thats about 3 and a bit I reckon if buying new, as closest you will get is the ED kit plus an aftermarket ECU and mine is on some 197 bits too which cost about 400 ish secondhand (head/cams/inlet)
Then the rebuild costs were approx (I dont keep receipts, lol)
Engine cylinder head rebuild:
parts : 500
labour : 0
Work done by Lesley Collis
Engine bottom end build and engine build up to mate head to bottom end with belts and gaskets etc :
parts : 2000
labour : 1 pizza hut and 2 harvesters
Work done by : Chip and Dan@SJM (formerly known as Danlp6 on here)
Gearbox rebuild with Quaiffe diff:
Parts : 1000
Labour (and rebuild parts) + transport : 400
Gear oil : 60 ish
Work done by: agency transmissions
Clutch
Parts : 500
Labour : zero
Mapping
Rolling road rental for half an hour : 25
Labour : zero
Fuel mapping on the road and on the rollers and to and from the rollers : 100
Work done by : Chip, with assistance from Lesley Collis
Then a couple of hundred in oils and filters and fluids for build and running in etc
So around the sort of 7K ish mark, although if you were paying labour you would probably be nearer the 10K mark all in.
Chi
  Z4, VW172, R26
Qwhen
parts : 500
labour : 0
parts : 2000
Parts : 1000
Gear oil : 60 ish
Clutch
Parts : 500
Labour : zero
Mapping
Labour : zero
Where can I see it in action? EPIC mate..
LiamR172
Scotland - NW
