viper hosing
  Ford F-150 5.4 V8
im sure this has bin mentioned b4 but ive done a search an cant find it so...
the intake pipe(the long black flexi 1) has colapsed an i have been searchin for somethin a bit more substantial to no avail.
however, i have also noticed a lot of people have managed to route the intake all the way to the lower front grill. the hose i was given was no where near long enuff.
so, has any1 else managed to find anywhere that sells 70mm ductin that wil flex enough to use and/or should i just ring pipercross an ask for a longer hose??
soz bout the long post.
i thought the Viper used a 100mm entry.
Demon Tweeks part number SFD-076 or SFD-102 wire supported.
  Ford F-150 5.4 V8
you may be rite, its just sat inb the shed at the mo!
cheers for the number!
Rich-D
  E90 LCI 330d
Must be the older style pipe you have?!
Mine is the wire supported stuff with the black plastic/rubber coated cloth tubing and theres no way it could collapse!
