Hi everyone and thanks for having me here.
I’m actually having idling issues with my 2007 Clio 3 Phase1 ( 1.4L 16v K4J 780 ).
Exactly 1 week ago, I started the car up, which it did very normally and was then idling at around 1000 rpm for the cold start. A couple of minutes later, the engine stalled abruptly and wouldn’t want to start up normally again unless you depress the throttle pedal to keep the revs. As soon, as you lift off, it idles very low ( 500 rpm ) and stalls right after.
I changed all 4 spark plugs and ignition coils and it’s now able to start up without having to depress the throttle pedal but is still very weak and stalls right after. Battery is quite new as well.
The engine revs to higher rpms normally without any problems or weird sound but it’s just that it cannot idle properly.
Any help or advices from previously similar situations would be most welcome.
Thanks in advance !
Cheers,
Neel
Thanks in advance !
Cheers,
Neel
