What exhaust hanger/part?
  clio 172 sport
Have a 02 172, exhaust is hanging, what bits am i likely to need & where should i source them? Easy to do job ?
Mr R.
  A special one.
Rear hanger and the middle one.
Adam @ Wolverhampton Renault.
Easy.
Maccy
  Straight 6
Give the bolts a good coating in wd40/similar before you attempt to undo them - they'll be damn tight!
  Renault Clio 172 cup
I got the rear mount off e bay new for about 7 quid but then didnt like the look of it and added some Sikaflex to effectively polybush it up. And as mentioned above the bolts will be well stuck in ,so give them a good soaking in wd or similar and just give them a little tighten first before you then back them off and undo them ( a mechanic mate told me this, the 2 I tried both heads came off and needed drilling, the 2 he did both came out without snapping ?? git ).
