I fitted 182 wheels on my DCI last year and used the same bolts, no problems. I had to replace all the bolts because some were faulty and snapping inside the hub. Ordered some from eBay for my car, but for some reason the cone head extends too far into the shaft not allowing it to tighten properly.
Are the bolts for the 182 the same for the DCI? I'm guessing that because I fit the same DCI bolts with the 182 wheels, there shouldn't be a problem. I am currently using M12 x 1.5 Taper 26mm
