Guys, my 182 is knocking at the rear when I lift off the gas / engine braking.
It sounds like the rear exhaust is knocking on the floor, but having poked around this morning I can't see anything loose.
The dogbone and driver side engine mount were replaced this morning and no change (although the gearbox feels nice and tight now).
The rear exhaust mounts are yellow aftermarket inserts, held in with cable ties, and they are not loose - but could these be the cause of the knocking? Maybe switch them out for OEM?
What else at the rear of the car could be causing knocking under engine braking?
