where is fuel cut of switch , car wont start
hi , my car has started to not want to start anymore , cranks over but doesnt fire and just cuts out half way through trying to turn over , changed the tdc sensor , checked battery , checked all fuses , all relayes , all connections , diagnostic comes up clear , this has only started after a new clutch was fitted though so im not sure if anyone has triggered the fuel cut of switch , where is it ???
  182 S
mine was doing the same yesterday! was the fuse for me! check again just incase. it was fuse 5 next to the battery ( not next to glove compartment ) the light brown one. had a tiny split in it, took me a while to notice. cost £1.56! soon as it was in fired up straight away :) hope this helps
B
bigrich690
mine was the fuse too, cant remember exactly where so adam 182 is prob right in where it is if it blows it cuts the fuel off and stops loads of other stuff from working too which you wont notice whilst the car is off took my brother in law over an hour to sort mine out when it happened and he has a full diagnostic kit and all it was was a tiny little fuse lol good luck pal
mgoode180566
  172 Sunflower
i had this. it was the fuel pump relay. swapped it for the cooling fan relay and away it went...
