Whistling Sun Roof
Hey, when my clio gets up t about 70 - 80 the sun roof starts whistling, anyone elses do this? (yes its shut properly :)
mine 16v 1 does it !!!
really pisses me off!i think it just aint sealing properly
i just open it a tad now it goes away
the french obviously had speed in mind :oops: annoying i open it a bit too but it makes different noise and cant decide which is more annoying
mine doesnt whistle... am i a freak? lol. after i hit that big fat kid its started rattling slightly when its open though, must have sent a shockwave through my car and knocked the sunroof as i ran over the overweight little s**t, lol
  Skoda Fabia vRS
just open it slightly, as said above, not so its open at all, but the handle is pulled like 1cm down, it pulls the glass tighter to the rubber seal
Electric :D mite say i was fiddling with it cos i thought it was dangerous and was gonna suck me out and then got flashed as i was distracted so if youd like to charge the points and fine to renault :)
yeh mine makes that friggen noise too, and it also leaks when when it rains heavy...fills up the sunroof switch casing with water and when I take corners it pisses all over me:mad:
handle?
thats ya ariel point leaking. do it up tighter
  Mk2 172
Clean the rubber, clean the inside edge of the sun roof, and vaseline your rubber.
It should stop the whistling or farting noise that some sunies make; it will get rid of the grit that lets water in; and it will make for a nice tight waterproof seal.
(Benj...no jokes about having a "nice tight waterproof seal" ! )
