mgoode180566
172 Sunflower
I see the arb mounts to the axle beam then picks up from the damper mount of the hub. Surely there is no load between these points.
Can anyone explain how the arb functions ?
When fitting arb to other cars have always fixed the bar to the chassis. The as each wheel goes into bump then the load in trasferred through the bar. Much like the arb on the front.
Is it the case for the clio that the arb simply stops any flex side to side in the axle beam ?
