You know when wheel bearings are gone when....
Tunst
  Focus ST225, Focus E
They come out in several bits....
Took this out of Nashys 182 on monday, after him bitching about an annoying wheel bearing noise..
I was expecting it to be quite worn but i didnt expect it to come out in different bits!
  Megane 225 F1
I never went in your 1.4.
Mine is making a noise at the moment but thought it might be brake related as my brakes squeal as well.
Rob
Like a humming, Will. Which increases with speed. You can easily tell its not the exhaust by disengaging the clutch and seeing if its still there. Also, swerving from side to side a bit indicates which side is fecked.
  S4 Avant
Yup got a bit of swearving which I put down to tracking. Might get the bearing checked out.
No, he meant if you swerve from side to side, you can hear which side makes more of a noise as you put pressure on that wheel. If you have a problem with the car tramlining that will be down to alignment.
If it's rear bearings that have gone, just replace the discs. Front bearings become a little more of a pain.
Tunst
Must've whined like a pig in a shredder!
It was horrific lol
Stupid question. What sort of whining does a f**ked bearing make?
Well it's more of a dull drone that gets louder the faster you go. I swear you were in my 1.4 once when I had mine go?
This^
It can also get louder the faster you go depending on how bad it is
Your telling me, everything was seized on this, it took 7 tonne of pressure to get that bearing outa the hub!
  Megane 225 F1
Deffo isn't the rear as I have just put new discs in.
Oh in that case I'l just sort the problem with the front brakes first and see if the noise goes.
Tunst
Find a straight bit of quiet road, and as rob says just drift from one side to the other, it will get louder/more droany when more pressure is put on the bearing thus telling you which side it is :)
  Mini Cooper S
50k and it was so loud couldn't hear the ktr exhaust!!! Like a jumbo jet was following me!! Yeah my nagging was justified in the end!! ;)
